surface reaction rate plot at diffusiion limit cas
Old   August 21, 2003, 16:20
Default surface reaction rate plot at diffusiion limit cas
Jason
I have a diffusion-limited case for surface reaction. So the reactant at surface is almost zero, and reaction rate is limited by the diffusion from bulk face, which is achieved by using a high pre-exponent factor value (1e15). The simulation shows that the gas products formed at solid surface diffused back into gas phase by plotting the contour of species, but when plotting x-y reaction rate on the surface, the rate is zero, any comments?
Thanks
Old   August 22, 2003, 05:54
Default Re: surface reaction rate plot at diffusiion limit
Greg Perkins
Have you tried looking at countours and/or ticking the node option?? I mean contours of the surface.
It may be a bug.
The reaction rate will have to be non-zero.
Greg
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
problem about porous media and surface reaction Jeff Lee FLUENT 3 November 24, 2011 14:46
Can Flow-3D plot the free surface area in Iso-surface or colour variable? therockyy FLOW-3D 1 June 20, 2010 20:36
Surface reaction rate Jon FLUENT 5 December 19, 2007 08:01
Reaction Rate Dhruv Siemens 1 October 1, 2005 11:34
