Plot drag coeff,lift coeff VS angle of attack
Old   August 18, 2003, 05:38
Default Plot drag coeff,lift coeff VS angle of attack
John
Hi.
I'm a new user of Fluent 6.
Currently,I'm doing a project. I need to plot drag coefficient, pressure coefficient and lift coefficient against angle of attack. I couldn't find the variables in the XY-Plot. May I know how to set up boundary conditions for changing angle of attack.
Thanks
Old   August 24, 2003, 11:43
Default Re: Plot drag coeff,lift coeff VS angle of attack
mateus
Hi!
What you will have to do is make a separate simulation for each angle of attack. The lift and drag coeficients can be obatined from "solve-monitors-force". To change the angle of attack you should create a new mesh each time - but it would probabilly take to long. if you are dealing with airfoil in wind tunnel you can define tunnel walls as periodic boundaries (place them far away from airfoil). This way you consider wing in allmols infinite space (no effect of walls and other objest in its vicinity). Now you can define the inlet velocity in components - vx and vy - for the desired angle of attack.
hope this helps
MATEUS
Old   August 29, 2003, 14:06
nikita
another suggestion is..for wind tunnel..u set the wall as symmetry
CFX convergence problem simulating ogive-cylinders at varied angle of attack jdacosta CFX 6 February 25, 2015 22:42
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
how to plot attack angle along with impeller span direction at leading edge wildli FLUENT 0 August 31, 2010 15:47
introducing angle of attack on ICEMCFD HEXA icem beginner Main CFD Forum 3 December 17, 2008 06:05
angle of attack kiran FLUENT 0 September 10, 2004 09:18
