How to read mesh data from ANSYS
Old   August 14, 2003, 23:26
Default How to read mesh data from ANSYS
mspilot
Dear all: Our labor has the ansys6.0 and fluent6.0. I try to use fluen to read the mesh data from ansys but just fail. It seems that only ansys5.4 and 5.5 are acceptable to fluent. Is that right?
Old   August 16, 2003, 06:36
Default Re: How to read mesh data from ANSYS
Lam
You only can import ansys 5.4 and 5.5. Refer to fluent User's Guide 5.3.6. But I think you should convert it through some universal standard like nastran, step or iges. But I have no idea about that.
Old   August 18, 2003, 18:06
emre
In ansys prep7/archive/write, and then in fluent file/import/ansys should work. (I did not check it out in ansys6.0, but I have 6.1, no problem in transfer) regards emre
Old   August 21, 2003, 07:00
mspilot
Thank you! I can do it now!
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Export icem-cfd mesh to ansys adam2008 ANSYS Meshing & Geometry 1 March 15, 2011 05:12
ansys imports icem-cfd ansys mesh adam2008 ANSYS Meshing & Geometry 0 March 5, 2011 09:40
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
