Converting 2D mesh to 3D
Old   August 6, 2003, 16:25
Default Converting 2D mesh to 3D
Farooq
hi...
I am undergraduate student in NUS doing a UROP project which involves the conversion of a 2D mesh created using GAMBIT to a 3D Mesh. The mesh is of osteosarcoma (bone cancer). I have been working on extending a current 2D mesh to 3D mesh and using existing modelling equations from the work of PhD students.
I already have a 2D mesh available. How can I use it to generate the 3D mesh? From what I know of Gambit, I think I have to make the 3D mesh from scratch.
I can make 3D mesh boundaries on my own or should I use existing CAT scans?
In any case, please advice.
Regards,
Farooq J.A.
Old   August 7, 2003, 06:03
Default Re: Converting 2D mesh to 3D
Simon Blakey
Hia Farooq,
I think the easiest answer to your question is "it depends"!
Certainly starting the 3D grids from scratch is more likely to result in a error-free mesh for export to Fluent, and if the geometery of the bone changes in the 3rd dimension this may be necessary anyway.
However, a short cut if you like would be to use the "sweep face" or "revolve face" functions to create a 3d volume from your 2d face.
I don't know wether it is possible to import data from CAT scans into fluent. It is probably possible through some intermediate software such as Pro-Engineer or CATIA. However, most of the experience people in my group have had would tend to indicate that it's easier to start from scratch with a slightly simplified geometery.
Finally, if the shape of the bone is reasonabely regular, then you could consider reducing the problem using symmetery, periodic or axis boundaries, which would reduce the time taken to converge to a solution.
Hope this helps,
Simon
Converting Salome hybrid mesh to OpenFOAM Arnoldinho OpenFOAM 4 March 28, 2012 11:24
[Commercial meshers] Converting a mesh with splitted cells using fluentMeshToFoam jlpelerin OpenFOAM Meshing & Mesh Conversion 4 April 25, 2011 17:56
[CGNS] converting CGNS mesh with cgnsToFoam bb_ OpenFOAM Meshing & Mesh Conversion 3 August 25, 2010 05:04
basic of mesh refinement arya CFX 4 June 19, 2007 13:21
