August 5, 2003, 15:52 |
udf to output velocity at some point
I'd like to write out the velocity vs time at several points. I defined some point surfaces, but seems I can't access these points by UDF. Anybody know if I am right or not? If I am right, so how can I output these stuffs? Any advice would be appreciated.
Jun |
August 6, 2003, 05:48 |
Re: udf to output velocity at some point
Hi, I don't think you need an UDF to do so. You can easily make a macro to save velociy at several point at every time step or more ! and get read the files normally named .out, with any text reader ! Ciao
August 6, 2003, 08:46 |
You don't need UDF for this. Just define your points in FLUENT and set a Surface Monitor on them, choosing the variable you want to monitor.
A monitor allows you to plot and save to file the values you need. Each monitor can save only a variable in a single point, so you need to define a monitor in each point for each variable you want to save. See the manual for more info. Hi ap |
August 6, 2003, 18:36 |
Hi, sorry , I mistook macro and monitor saving. yeah, that's right, follow the advice of Ap above !!!
bye |
August 19, 2003, 14:43 |
Thanks a lot, guys.
UDF for Inlet velocity | Mijin Kim | FLUENT | 0 | September 28, 2009 05:50 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 03:27 |
How to output unsteady velocity profiles? | Jason | FLUENT | 3 | August 8, 2007 10:40 |
Urgent! Help on UDF to set inlet velocity | Ray Hong | FLUENT | 4 | December 30, 2005 13:32 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 12:21 |
