how set a source inside a flow domain
Old   August 4, 2003, 09:48
Default how set a source inside a flow domain
Jason
where the source size is not small (comparable to cell) at all. So we can not use the source definition technique with tiny inlet.
How to set it? The source is actually located in one end of tube, which is immersed in a large tank. The flow out of other end of tube will mix with the fluid in tank.
Thanks.
Old   August 8, 2003, 17:23
Default Re: how set a source inside a flow domain
Amit
You can try to write a user defined function aka UDF Modify the file below to suite you. The code below is transient too. Remove if not requried
#include "udf.h"
DEFINE_SOURCE(mass_source, cell, thread, dS, eqn) { real time_step, time_size, curtime; real source; real x[ND_ND];
time_step=RP_Get_Integer("time-step"); time_size=RP_Get_Real("physical-time-step"); curtime=time_step*time_size;
C_CENTROID(x,cell,thread); if ((x[0]>=40.0 & x[0]<=40.2) & (x[1]>=0.0 & x[1]<=0.2))
source=1000*exp(-curtime);
else
source= 0;
return source;
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Monitor flow through a cross section inside domain Kushagra Mittal CFX 4 August 5, 2008 23:40
Modelling the Heat flow inside the curing oven Marios Vlad CFX 1 February 6, 2008 08:11
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
