Gravity influence of flow :Urgent
Old   August 3, 2003, 13:41
Default Gravity influence of flow :Urgent
Suresh Balasubramanian
I have laminar flow through a pipe intersection and i want to see the influence of gravity?
I turned on the gravity option and also set the operating density to zero. When I solve using velocity at the inlets & pressure at outlets I see that the residuals don't go below 1e-3. They keep varying at a residual value of greater than 1e-3 I have a terahedral meshed 3-D domain.
When I stop the iterations I see a Hydrostatic pressure distribution which is correct.
I also see that some of the velocity vectors point out of the domain. (Seems as if inclusion of gravity makes the vectors point out of the domain).
If anyone of you have seen a similar problem I would be greatful if you can help me. It's urgent.
Thank you very much,
Suresh
Old   August 4, 2003, 06:11
Default Re: Gravity influence of flow :Urgent
Mcgregor
Hi Suresh
If you identify which residulual is not going below 1x10 -3 then you can go into the solve/control/solution panel and decrease the relaxation factor relating to that variable (ie continuity). This should solve this problem as the solution will then converge
Mc
Old   August 4, 2003, 09:28
ap
Try reducing momentum under-relaxation factors.
If you're using an high order discretization scheme, try to obtain a first solution using the first order scheme, then switch to the higher order one.
Hi
ap
Old   August 6, 2003, 12:06
Evan Rosenbaum
While I've only used gravity when evaluating buoyancy problems, I'm not sure you should specify a zero operating density. The gravitational force on anything without mass is zero.
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
Urgent Help !!!Strange reverse flow in naca0012 problem parvez2683 FLUENT 5 May 20, 2013 10:25
urgent: Creeping Flow (Re=0) emad FLUENT 0 August 5, 2009 03:31
help needed in Turbulent flow (URGENT) mike FLUENT 7 November 7, 2008 07:11
Jet flow problem.. PLZ help URGENT!! Vinayak CFX 1 April 3, 2008 19:02
