ask help on valve flow simulation(3D modelling)
Old   July 18, 2003, 18:39
Default ask help on valve flow simulation(3D modelling)
Anna
Hello, anybody can give me hints on a flow control valve simulation? I created a 3D modelling, a big up oil container and a small valve at bottom. Here are some boundary conditions defined: 1 unsteady laminar flow, under atmospheric pressure operation condition, only gravity causes the flow; 2 one phase fluid, because it will work on unpredictable temperature, so I set energy in.
Because I am a newer on FLUENT, so all the time I got rubbish results. So what should be correct settings? I did setting on Define-model,energy, viscous ; material; operation condition; boundary conditions; solver-controls; solution; initilize and iterate.
Sometimes the iterate doesn't run or just appears one convergence, 0; sometimes the result on pressure is decreasing along the gravity direction. And where is the correct reference pressure location?
Please tell me what shall I do on this modelling, I really need your kind help.
Simulation of air flow inside valve - FSI? Help! farianka Main CFD Forum 0 April 17, 2011 17:30
VOF modelling open channel river flow Matthew Roberts FLUENT 6 July 31, 2009 13:52
Turbulence modelling validation : Orifice flow Joe Main CFD Forum 2 July 26, 2006 17:41
modelling slug flow with pressure inlet Azman FLUENT 0 May 29, 2006 07:45
Compressible Flow Modelling? yeo FLUENT 4 March 7, 2003 08:08
