unknown interiors in domain
Old   July 9, 2003, 12:56
Default unknown interiors in domain
Mark
When I exported my grid from gambit to fluent I find that there are two 'interiors' that i did not put into the domain. These interiors are faces. I did not put them there intentionally and I cannot find them in gambit, to delete them. I would like to know if they will have any effect on the solution or can I ignore them?
Thanks for your help,
Mark
Old   July 11, 2003, 22:05
Default Re: unknown interiors in domain
ap
Check the grid using the check function in FLUENT (Menu Grid -> Check). If the mesh passes the test, it should be ok.
However, pay attention when you load the mesh (.msh file) for the first time. Maybe FLUENT gives you some warning message telling you it is adding something or modifing your mesh.
Hi
ap
[Commercial meshers] fluent3DMeshToFoam bego OpenFOAM Meshing & Mesh Conversion 31 August 16, 2023 10:04
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 17:14
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 23:43
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
