Mean mass flow rate
Old   July 1, 2003, 08:07
Default Mean mass flow rate
Adel
hallo, I am working with the VOF-modell and I want to calculate the mean mass flow rate within a period of time at the outlet during batch calculation mode. Has anybody an idea how to do that? Thanks in advance
Old   July 1, 2003, 17:18
Default Re: Mean mass flow rate
ap
Enable the Data Sampling for Time Statistics on the Iterate panel.
Then define define a Custom Field Function in which you specify Q = rho*v_avg*S, where rho is the density of the flow, v_avg is the time averaged velocity (you can find it in the Unsteady Statistics list) perpendicular to outlet and S is the section of outlet (if constant, just insert the value, else omit it: you'll obtain the mass flux instead of the mass flow rate).
To obtain the mean value on the surface, just use the Report->Surface Integral function to obtain a area weighted average of the Custom Field Function you defined.
That's should be the value you're looking for.
Hi
ap
Old   July 2, 2003, 11:24
Adel
Thank u ap. I'll try it! Ataki
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 10:58
CFX turbo - Mass flow rate Vashishth Patel CFX 7 April 3, 2014 21:33
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 03:42
negative global mass flow rate Gimli FLUENT 0 April 21, 2006 08:17
mass flow rate error Masood FLUENT 0 May 22, 2005 01:32
