Question on Face Temperature Gradient
Old   June 25, 2003, 06:16
Default Question on Face Temperature Gradient
Tomasz Didenko
Hello
I'm a Phd student and I use Fluent software in my Doctor's degree preparation. In my doctoral I do computer modeling and simulation of laser welding and compare this results with experimental cross section of microphotography.In fluent manual, Face Macros haven't temperature gradient vector.I can't add the the _G suffix to access the tempearture gradient something like this -> F_T_G(f,t). Therefoe I'd like to ask how to compute face temperature gradient in UDF.I want to apply this face tempearture gradient to Marangoni phenomenon in specified shear.
Bye bye
Tomm.
Old   June 27, 2003, 05:30
Default Re: Question on Face Temperature Gradient
Mcgregor
Hi Tomm,
If you use the F_T_M1 (i think its m1, but check the user guide)this will give you the temperature at the previous time step.
You can then calculate the gradient using (change in y value)/(change in x value).
ie. in your UDF: gradient = (F_T - F_T_M1)/(timestep size)
Hope this helps
Mc
How to get the temperature gradient in CFX post Jay CFX 4 January 7, 2015 04:23
Temperature Gradient at Wall sven OpenFOAM 7 November 1, 2010 18:25
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
