volume meshing
Old   June 18, 2003, 04:48
Default volume meshing
nikita
hello...i am having a problem in volume meshing.everytime i join 2 volume into one, then i have an error when i am meshing volume..it said that i should check the skewness of the face meshes and mesh are too big for small gap...pls advise.
Old   June 19, 2003, 05:38
Default Re: volume meshing
neu
* use different mesh sizes * may be your geometry is not connected * use a different way to construct geometry + can you explain a little bit more about your geometry so that a right suggestion can be made
Old   June 20, 2003, 23:25
lee
Try to connect faces, edges, vertices first. You can use virtual operation. I guess you may have disconnected geometry which create very small gap.
How did you create your geometry?
Old   June 21, 2003, 03:31
Rahul
Try to change mesh specification while meshing or if very small surfaces result from joining opreration, try to merge them.
Old   June 25, 2003, 02:34
Alamgir
By which operation u just join them? split or combine? check how many volume are there,, delete volumes if that are uses anyhow.
Alamgir
Old   June 30, 2003, 06:11
nikita
hello friends..i still have a problem on volume meshing.i draw a small aircraft model and the model will put in the wind tunnel.so i draw the half model of the aircraft, and then create a brick which will be assume as a wind tunnel.the dimension of wind tunnle is (1*1*2.5)M.after creating this two volume, i subtract it in to 1 volume.the problem appeared when i mesh the volume,it said that check the skewness and maybe the face mesh is too big for a small gap..then i shift the position on one part of the aircraft, then, the volume mesh is success..the problem comes again when i try to export to fluent.the error is sound like this: A DEFAULT (UNSPECIFIED) BOUNDARY WAS CREATED ERROR:AN INCORRECT MESH HAS BEEN STORED.CHECK MESH QUALITY BEFORE EXPORT. VOLUME 3 HAS INCORRECT MESH AT FACE FACE63... pls advise
'Tetrahedral meshing has failed for volume...' Murat FLUENT 5 February 19, 2011 05:22
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
Meshing volume F.A. FLUENT 3 December 12, 2005 02:31
volume meshing nikita FLUENT 1 July 3, 2003 02:25
Patran Volume Meshing Deb CFX 19 April 17, 2003 11:56
