examples of simulation on room ventilation?
Old   June 15, 2003, 06:11
Default examples of simulation on room ventilation?
lei
Hi, all I am a newer of Fluent/Gambit. I wonder if you could help me to make detailed meshes at the places I wanted, such as meshes on the vents/openings, meshes near walls.
Alought I tried to set the mesh for edges for the vent, it doesn't work when I meshed the whole room as a volume, when the room is meshed by the type of Hex. Could you give some examples of simulation on room ventilation? Pleast send me the "dbs" files or "jou" files, if you have some examples.
I looked up the Tutorial of fluent/gambit, but there is less examples on room ventilation. So far I has not quite understood the meshing method. Is there any databases for examples of fluent/gambit?
Any hints are welcome. Thanks in advance.
Old   June 20, 2003, 23:38
Default Re: examples of simulation on room ventilation?
lee
Yes, you can make stretch mesh using boundary meshing (near boundary) or using size function.
[GAMBIT] Object in room with that object being the purpose of investigation fluentgambituser ANSYS Meshing & Geometry 3 August 24, 2011 02:52
HVAC Modeling Humans in Room LilBort CFX 27 July 31, 2009 12:08
flovent or airpak for ventilation simulation stéphane Main CFD Forum 3 October 13, 2007 05:55
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
Question concerning about the flow simulation of a fan in an engine room. ghlee Main CFD Forum 3 October 21, 1998 08:05
