Macros for writing UDF for porosity
Old   June 13, 2003, 02:22
Default Macros for writing UDF for porosity
umesh
hi I want to write a UDF for a packed bed it has three layers of packings,with porosity 0.27, 0.3 and 0.35 respectively
i am working with fluent6.1 I read the manual, but cant find how to define/ write UDF for variable porosity
i only found i had to use DEFINE_PROPERTY macro.
anyone having some idea/ sample UDF, Please reply soon. Its Urgent thanks in advance
Old   June 13, 2003, 05:20
Default Re: possible options
umesh
Hi I received follow information, hopefully it will help others also........
If your porosity is fixed for the simulation, as you seem to indicate, then I suggest that you simply use Gambit to define a mesh with three fluid zones, one for each layer. In each fluid zone you set the boundary conditions and turn on porous zone and set the constant porosity you want.
If you want porosity to have a complex variation or it changes with solution time etc., you can use a PROFILE function. The manual is wrong and it must be a profile udf not a proprty udf!!!! (Just found that the other day!). I've also had some problems with loading cases with a profile defined, so it may have other bugs since this is new in 6.1.
An example profile is:
DEFINE_PROFILE(PROF_Pm_Zeta,thread,i) { cell_t cell;
begin_c_loop(cell,thread)
F_PROFILE(cell,thread,i) = /* put your function here */
} end_c_loop(cell,thread) }
I'd try the first option before using a udf!!
Have fun
accessing solver data with UDF macros Dushan FLUENT 1 April 22, 2017 22:05
Help! where to find full UDF Macros and functions kim FLUENT 6 March 5, 2014 10:01
UDF: Previous time step macros NOT working jpapg FLUENT 0 April 30, 2011 22:35
What are UDF macros C_T_S , C_T_AP,...???? Asghari FLUENT 0 January 28, 2007 11:54
udf error in some macros Asghari FLUENT 0 August 7, 2006 02:10
