June 11, 2003, 06:35 |
Flunet 6.1, error message
hi i had just installed fluent 6.1
on the same PC, i had previous version fluent 6.0 both versions seems to be working properly but while startup of fluent 6.1, it gives the message in console window Error: sopenoutputfile: unable to open file for output Error Object: "c:\temp\kill-fluent1348" what could be the reason!!!!! thanks in advance |
June 11, 2003, 06:51 |
Re: Flunet 6.1, error message
You should create a directory 'temp' on your C: and it will be fine.
June 11, 2003, 08:51 |
hi thanks for ur suggestion after i created a dir "temp" in C: and started fluent there is another message
Kill script file is c:\temp\kill-fluent732 just for curiosity, what does this message indicate!!! Regards |
June 11, 2003, 09:06 |
The number is the PID of the software. If fluent crashed down you can kill the process using this number. It's not necessary under Windows because you have directly access to the list of process.
Installing Fluent 6.1 in Solaris 5.10 | saa_pondy | FLUENT | 0 | August 30, 2006 09:21 |
Standard convergence limit in FLUENT 6.1 | Henrik Ström | FLUENT | 3 | December 20, 2005 09:48 |
TUI Mass-flow-rate input with Fluent 6.1 | Jeremy | FLUENT | 0 | December 12, 2005 16:00 |
Running FLUENT 6.0 sims. on FLUENT 6.1 | ozgur | FLUENT | 2 | April 2, 2004 14:23 |
Multiphase modelling in 6.1 | Harshal | FLUENT | 1 | May 20, 2003 13:44 |
