Boundary Conditions
Old   June 9, 2003, 06:44
Default Boundary Conditions
Ian Hunt
I am trying to model two cases of the flow of water through a geometry at 1m/s. In the first case I would like the water to be pushed through the geometry and I have set my boundary conditions to a velocity inlet of 1m/s and a pressure outlet at atmospheric, however, in the second case I would like to suck out the water at the same velocity (1m/s). What bounday types should I use? Can I have a velocity inlet of (-1m/s). Or should I use a pressure inlet and outlet in both cases? Any advise?
Old   June 10, 2003, 02:35
Default Re: Boundary Conditions
Alamgir
In your 2nd case you could use outlet as a velocity inlet setting -1 m/s (as u said) or you could set outlet as an outflow... it will give same mass flow rate.
Alamgir
Old   June 10, 2003, 07:42
Ian Hunt
If I was to set the outlet to an outflow as suggested... Will that not give me the same conditions as case 1 where the water is being pushed through. Basically I want to see if there is any differences (forces on the walls) if the flow was pumped through or sucked through? Or would they be the same? Any thoughts?
Old   June 25, 2003, 01:59
Alamgir
No, it'll not be same as case1, for the boundary condition when u set outflow, it actually mean volume flow rate remain same, as much as water enters thru inlet, same amount of water will pass no matter what is the pressure. Pressure would be different, case1 inlet pressure will be more than atm, this case pressure at outlet will be less than atm. So pressure distribution will be only different.
Alamgir
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 13:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 08:21
OpenFOAM Variable Velocity Boundary Conditions NickolasPl OpenFOAM Programming & Development 2 May 19, 2011 06:37
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 10:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
