Can't figure which cell particle is going to
Old   June 6, 2003, 14:55
Default Can't figure which cell particle is going to
rookie
Hello All, Does anyone know what this error message means in the DPM? "Can't figure which cell particle is going to -- ABORT." Thanks a lot!
rookie
Old   June 6, 2003, 15:01
Default Re: Can't figure which cell particle is going to
Alex Munoz
Hi
This message means that FLUENT is able to intermpolate the position of a particle. Therefore, it abort the calculation and move to next particle on the list.
Do not worry about this message it is one particle out of 10000 particles that you are using in your simmulation.
Best Regards
Alex Munoz
Old   June 12, 2003, 21:35
rookie
Thank you! Alex. I changed the size of particles, and this error message is gone. I wish Fluent released some kind error message manual.
Thanks again.
Old   December 8, 2017, 10:07
Hells Blade
hellsblade.91 is on a distinguished road
Hi alex what did you do when you had this problem how did you rectify it ?
hellsblade.91 is offline   Reply With Quote
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Can't figure which cell particle is going to -- AB am FLUENT 0 February 21, 2006 19:13
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Warning 097- AB Siemens 6 November 15, 2004 05:41
Can't figure which cell particle is going to? Easycad FLUENT 4 November 13, 2003 08:18
