June 4, 2003, 12:38 |
UDF Boundary Condition
When using a UDF to implement a BC does the profile have to be a continuous function or can you insert specific points on the boundary and have Fluent fill in the gaps.
Thanks for your help |
June 4, 2003, 13:27 |
Re: UDF Boundary Condition
I do nto think u can think of FLuent filling the gap. You have two options:
(1) define a profile (2) read data from a file for the mesh points I donot think any other method works. Murali |
June 4, 2003, 17:53 |
You can interpolate your data and implement the equation you obtained in a UDF.
Hi ap |
June 4, 2003, 22:41 |
Maybe you do not explain your problem cleasly. if you want to define a function along the boundary, it is simple. if you want to define an incontinuous boundary condition on the two sides of the boundary, it can be implemented by UDF.
June 6, 2003, 16:17 |
Thanks for your help. What I have is a 2-D boundary plane on which I will know velocities at cerain points in a grid taken from experimental data. From what you've said I will use a math program to create a function from the velocities and then use a UDF to implement it, unless someone knows of a better way.
June 7, 2003, 10:09 |
you can give your data points through piecewise linear function.. But I dont know how actually works.. c the fluent manual for B.C.
Mahesh |
Resolved: Changing boundary condition with UDF according to pressure outlet boundary | alpemre | Fluent UDF and Scheme Programming | 12 | February 24, 2014 10:18 |
UDF for inhomogenous Neumann boundary condition | akhilesh | Fluent UDF and Scheme Programming | 3 | December 24, 2012 11:14 |
Boundary Condition Types Using Scheme and UDF | Nasir | FLUENT | 0 | September 15, 2008 21:54 |
UDF for the boundary condition | Sridhar | FLUENT | 3 | July 13, 2001 19:18 |
UDF : boundary condition ID | Flav | FLUENT | 4 | June 28, 2001 09:52 |
