phase transforming with heat transfer
Old   May 31, 2003, 22:46
Default phase transforming with heat transfer
Danual
i want to simulate the process of liquid water transforming into vaporate water flowing in a hot duct. But i don't know which model i should used. Because all the multiphase models don't considerate the evaporation progress. what should i do?
Any help will be appreciated! Thank you!
Old   June 1, 2003, 09:36
Default Re: phase transforming with heat transfer
mateus
Hi!
I think the best possibility is VoF multiphase model with UDF for mass transfer (you have an example for UDF defining mass transfer due to incerased temperature).
regards
MATEUS
Old   June 1, 2003, 13:43
Danual
Thank you for your help. But the vof multiphase model just model the two phases which don't penetrate into eath other. The most difficult thing i face is how to considerate the heat transfer between the two phases and the transforming of liquid into gas. i appreciate any help. Thanks again!
Old   June 2, 2003, 08:12
mateus
Hi!
If the two phases do not penetrate each other means that there is a defined boundary between them (in your case boiling - liquid and wapour). The case where they are penetrating each other is for example mixture of water and alcohol (no boundary between liquids can be defined).
As I told you you can find an example of heat transfer and mass transfer in fluent UDF documentaion. Hm. I forgot to ask you - which fluent wersion are you using - with fluent 6.1 it's possible to do this, but I'm not shure for previous versions.
Anyway - check UDF documentation (FLUENT 6.1 - chapter - 4.4.2).
REGARDS, AND GOOD LUCK
MATEUS
Old   June 2, 2003, 13:52
mateus
Hi!
I have sent you the documentation - i hope the adress was correct - I've had some problems with it...
have fun
MATEUS
Old   June 3, 2003, 13:38
Danual
It's a great help! Thank you very much.
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 09:46
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
CFX Heat Transfer RJamison CFX 0 July 24, 2008 13:11
VOF model for the two phase heat transfer Dibakar Rakshit FLUENT 2 April 7, 2008 04:43
help needed about phase change Yanhu Guo Main CFD Forum 4 January 24, 2001 00:16
