COnvergence Problem !!!!
Old   May 27, 2003, 13:30
Default COnvergence Problem !!!!
Mohamed
Hello
I'm using VOF (water + air) model Geo-reconstruct, PISO, PRESTO, with good mesh (skewness <0.82)
The problem is : all equations converge very well whereas COntinuity still oscillating about 0.003!!! does any one know why? or how to resolve?
Thanks in advance
Mohamed
Old   May 27, 2003, 15:37
Default Re: COnvergence Problem !!!!
Shiping Liu
did you try smaller under-relaxation factors?
Old   May 28, 2003, 03:56
Mohamed
Hi Liu and all,
For which parameters should I reduce this under relaxation factors.
I worry that computation will become very much slow with a small time step (0.0001) and smaller under relaxation factors !!!
Is there any rules in modifying these under relaxation factors. I know only that for momentum and pressure , the sum should be 1 (0.3 + .07 for example)
Thanks In advance, Mohamed
Old   May 28, 2003, 04:35
mateus
HI!
I think the best for you is to chech the messages on forum - there has been A LOT of discusions about convergence with VOF model.
And don't play to much with undre relaxation...if you decerase them to much, your solution will converge but it will take a very long time and the solution might be wrong. I think 0.3 is the minimmunm.
Regards
MATEUS
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 07:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 04:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 01:24
