help on convergency..
Old   May 26, 2003, 04:55
Default help on convergency..
heydari
Dears, I have simulated a jet flow but as I enlarge my domain, the created vortex expands too. The iteration no exceeds 4000 but the convergency, remains to approx. 0.1 with some periodic changes. the vel. and pressure changes in one point do not reach to a constant value. thanks for helping me...
Old   May 26, 2003, 15:31
Default Re: help on convergency..
Colin
Hi, Heydari. I also posted a question about convergency some days ago, and I get a kind reponse form AP. Here are his suggestions, hope they could give you some help. ================================================== ========== Re: Convergence Question
Posted By: ap <apnews@infinito.it>
Date: Wed, 7 May 2003, 6:51 p.m.
In Response To: Convergence Question (Colin)
Hi Colin, I don't know the problem you're solving, so I'll try to give some general advice.
- First of all you should check if your problem is well-posed. Verify all boundary conditions.
- Check your grid and refine it, if necessary.
- If you're doing unsteady calculations, try to reduce time step and/or increase the number of iteration per time step.
- Try to reduce under-relaxation factors.
- Try different discretization schemes.
- Change solver settings in the Solve->Multigrid dialog box (read the manual for more info).
Hi
ap
Old   May 28, 2003, 06:49
heydari
Dear Colin, Thanks for your advice, I have checked those recommendations, but the answer is not gotten better.
Convergency a.etesam FLOW-3D 2 May 30, 2009 02:10
convergency problem at mach 3 emrah FLUENT 0 May 21, 2008 02:39
Convergency Pandaren Brewmaster Main CFD Forum 0 April 3, 2008 02:03
oscillatory residuals & slow convergency in SIMPLE Ahmad Falahat Pisheh Main CFD Forum 0 January 5, 2004 17:43
Convergency Difficulty!! Min-Hua Wang CFX 8 November 14, 2001 14:31
