UDF reading the temperature gradient
Old   May 23, 2003, 05:15
Default UDF reading the temperature gradient
Fabian
does anybody know how to acces the z-component of the temperature gradient with an UDF? My UDF works well as long as I define a certain value to the temperature gradient, but when I try it with :
' dT_dz = C_T_G(cell,thread)[3]; '
FLUENT gives me an Error:
' FLUENT received fatal signal (ACCESS_VIOLATION) '
Greetings Fabian
Old   May 29, 2003, 21:18
Default Re: UDF reading the temperature gradient
ap
Gradients are not defined at the first iteration. Put that command in an if like this:
if(Data_Valid_P()) { ... }
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 07:37
Temperature Gradient at Wall sven OpenFOAM 7 November 1, 2010 18:25
temperature normal gradient on a boundary Sandrine Main CFD Forum 2 June 10, 2009 17:34
normal temperature gradient on a boundary Sandrine FLUENT 0 June 10, 2009 13:29
UDF or any approach for Bulk Temperature calculation vemps FLUENT 0 May 1, 2009 02:09
