momentum exchange of coupled DPM!!
Old   May 15, 2003, 23:12
Default momentum exchange of coupled DPM!!
winnie
Hi
I have some questions about the momentum exchange calculations in coupled DPM.
The exchange is calculated via the equation:
F=¡Æ(drag_force+other force)*mass_flow*time_step
Can you tell me if I have four injections each with a definite mass-flow rate, how does the fluent calculate this exchange value when I use following methods:
(1) a steady calculation with only four particles tracked ;
(2) an unsteady calculation with both injection start time and stop time set to zero(that is to say, during the calculation, there are only four particles in the field);
(3) an unsteady calculation with a difference between start time and stop time(that is to say, during each iteration time step, there will be other four paricles injected into the field and the particles in the field are accumulated);
Any help will be appreciated!!
Regards
winnie
coupled DPM Peter Kolb FLUENT 5 October 4, 2012 11:27
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 20:53
DPM Coupled Implicit Aimara FLUENT 0 April 25, 2007 17:23
problem on DPM coupled with CFD harry Main CFD Forum 0 June 2, 2005 07:12
FEM fortran codes for coupled mass momentum energy Amit Main CFD Forum 1 May 17, 2005 21:38
