Variable physical properties of fluids/solids |
May 11, 2003, 09:23 |
Hi, is Fluent include all the change of physical properties in materials? For example density, Cp, viscosity change with temperature. I don't want Constant physical values for a fluid but all of them.
I have to enter manually the polynomial equation (piecewise linear or polynomial) to relate these facts or is it already included?? Thx a lot. |
May 11, 2003, 12:35 |
Re: Variable physical properties of fluids/solids
You have to manually insert polynoms coefficients in the Materials dialog box.
ap |
May 11, 2003, 12:46 |
Oki thx ap They should be put these data in fluent directly, it's a loss of time for us.
May 11, 2003, 16:37 |
Polyomial expressions are not valid in all ranges of their parameters, so a complete database should contain different expressions for the same datum in different ranges. And for a single datum, the solver should decide which expression is valid.
I think it's better to leave the user decide which expression is better to use, even if this is time consuming However, you can find a complete database integrated in Aspen. Hi ap |
May 11, 2003, 16:56 |
My temperature range is quite small [20°C to 50-60°C] and only for water. I must verify but I think I have all values for density, Cp, k at each temperature so it's not a problem. I'll do probably a piecewise-polynomial because more easy than calculate the polynomial regression.. And I'll save it in propdb.scm to avoid re-type it again and again
I don't know what is ASPEN , I'll do a search on Google Thx |
May 11, 2003, 17:06 |
piecewise-linear I want to say not polynomial
May 11, 2003, 17:10 |
If you don't want to calculate expressions by yourself, try to look for them in the Perry's Chemical Engineers' Handbook (McGraw Hill).
Hi ap |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 10:14 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 05:35 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
Physical properties of radicals for NOx modelling | Jirka | Siemens | 5 | May 19, 2002 02:45 |
