cut plane?
Old   May 10, 2003, 23:29
Default cut plane?
qiaomu
I simulted a 3-d channel. I can cut the duct at every location to get a plane. but how can I only get a part of this plane. Thanks
Old   May 12, 2003, 18:24
Default Re: cut plane?
Shiping Liu
I don't know how to get a part (what shape?)of a cut plane with Fluent. One alternative way is to export this cut plane into a finite element file like Tecplot file, and then you can take any part of this plane using a interpolation.
View with cut plane Mudblood FLUENT 5 April 4, 2020 11:17
[ICEM] cut plane visualization Will Anderson ANSYS Meshing & Geometry 12 August 26, 2015 15:20
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
[OpenFOAM] View the pressure drop contour in a cut plane 2D in a right position zhoubinwx ParaView 3 February 13, 2008 05:46
