Convergence Question
Old   May 7, 2003, 19:59
Default Convergence Question
Colin
Hi, there. If the residual of continuity doesn't fall below 0.001, what should I do to get convergence? Adjust relaxation factor? Or adjust the mesh? Anything else? What the "thumb of rules" of these adjustments?
Old   May 7, 2003, 21:51
Default Re: Convergence Question
ap
Hi Colin, I don't know the problem you're solving, so I'll try to give some general advice.
- First of all you should check if your problem is well-posed. Verify all boundary conditions.
- Check your grid and refine it, if necessary.
- If you're doing unsteady calculations, try to reduce time step and/or increase the number of iteration per time step.
- Try to reduce under-relaxation factors.
- Try different discretization schemes.
- Change solver settings in the Solve->Multigrid dialog box (read the manual for more info).
Hi
ap
Old   May 7, 2003, 22:13
raintung
I met the same problem, convergence approach steadily at first, but then the residuals will level off(explict solver). I don't know what should I do. I set the some of the parameters under FAS Multigrid Controls , but divergence appears.
Old   May 7, 2003, 22:47
Colin
I think AP has given us some good ideas. Just try, maybe it works.
Thanks Ap.
Old   May 8, 2003, 10:34
ap
If you give some datail of the problem you're solving, maybe I can be more specific.
Hi
Old   May 8, 2003, 22:13
raintung
Can you give me some advice? I am simulating the 3Dflow field in compressor. The mesh is semi-structured and the boundary conditions obtain from the experiment. Because there is a thin fence on the endwall, it is very difficult to get desirable mesh and convergence is not easy. I use k-eplison Realizable model. What should I do? Thanks.
Old   May 9, 2003, 09:59
ap
It seems a complex situation...
I assume your boundary conditions are good, because you have them from experiments.
So try to check mesh quality and, if possible, refine it where quality is really low. You can try to remesh your domain using unstructured grids, if it's too difficult to refine the semi-structured one.
If this doesn't work, try to reduce under-relaxation factors and to increase the number of iteration on the internal cycle (Multigrid panel).
However, changing parameters of the solver may help, but doesn't solve problems due to a poor quality mesh
Good work
ap
Old   May 9, 2003, 22:13
raintung
Thank you. I will try to do that.
Old   May 9, 2003, 22:47
raintung
Can I ask you a simple question? We often say ˇ°refining meshˇ±, but how many means can we do that effectively? Thank you.
Old   May 10, 2003, 19:21
ap
I'm not sure I understood your question.
You want to know how you can refine a mesh?
Personally, I don't like grid adaption tools which are integrated in FLUENT. Usually they increase too much the number of cells.
I prefer to use Gambit and to remesh the system by hand, choosing the number of nodes on the edges of my domain where I want to improve mesh quality. It requires more time, but I think it can give better results without increasing the number of cells too much.
Hi
Old   May 10, 2003, 22:02
  #11
raintung
Thank you! I think it is a good idea. I quite agree with you.
Old   May 16, 2003, 05:41
  #12
phil
when you remesh in gambit, is it possible to then effectively patch the data from the previous analysis even though the mesh has changed?
Old   May 16, 2003, 09:35
  #13
ap
If the geometry doesn't change, you could use the Grid-to-grid solution interpolation function.
See the post: GRID TO GRID INTERPOLATION in FLENT for a link to the page of the manual.
Hi
ap
Old   May 16, 2003, 12:41
  #14
phil
cheers ap i was fairly sure it could be done but didnt know what it was called!
Time step dependence of convergence behavior of steady state simulations in CFX Chander Main CFD Forum 5 December 23, 2013 06:31
Convergence Question racerdude777 Main CFD Forum 2 March 14, 2011 23:07
Convergence Question James FLUENT 2 October 29, 2005 15:59
Question about convergence criteria? Thomas FLUENT 7 April 8, 2005 20:38
help! cyclone convergence question Lcw FLUENT 1 January 26, 2005 16:29
