gambit mesh about a wing
Old   May 5, 2003, 09:55
Default gambit mesh about a wing
Indi
Can somebody give some suggestion in generating a mesh using gambit for a typical external flow problem (RANS), say an Onera M6 wing?
My particular problem is the bundary layer mesh around aerofoil trailing edge. Whilst the b.l. function seems to give reasonably well behave cell around the region, the actual mesher always produce distorted cell. (I need y+<=5 for the first b.l. which translate to y<=2e-6 for typical problem)
I've seen the potential offered by size function that is availabe in v.2.0, but I can not managed to get a grid with similar cell distribution from those of vgridns or centaur. Again, it is the TE region that seems to be the problem.
Cheers
Indi
Old   May 5, 2003, 12:27
Default Re: gambit mesh about a wing response
cip
use a tools/size functions, for creating your own tipe of mesh. boundary layer for complex regions give always problems
Converting Fluent mesh files to Gambit neutral files samuelkc ANSYS Meshing & Geometry 9 April 21, 2021 07:28
[ICEM] Structured Mesh 3D Wing Tip Michiel ANSYS Meshing & Geometry 5 October 21, 2010 09:39
Mesh Resolution in Gambit Vidya Raja FLUENT 2 January 19, 2006 00:35
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 04:10
