Static Temperature
Old   May 5, 2003, 06:35
Default Static Temperature
Parshant Dhand
What does the static temperature parameter mean in the Display / contours menu?
How is it different from Total temperature?
What does the two temperature signifies physically?
Old   May 8, 2003, 17:54
Default Re: Static Temperature
Shiping Liu
please read the manual. For incompressible flows,the total temperature = static temperature.
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 05:24
Tf is averaged by static or total temperature ?? NPU_conanxie Main CFD Forum 0 April 6, 2011 22:30
Bulk temperature Tf is obtained from total or static temperature? NPU_conanxie FLUENT 0 March 30, 2011 06:56
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 06:08
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 01:49
