turbulent model
Old   May 5, 2003, 00:33
Default turbulent model
Michelle
hello everyone
Any opinion on suitable turbulent model for highly swirling turbulent flow? Which of the model can capture the velocity structure best?
Thanks
Old   May 5, 2003, 05:27
Default Re: turbulent model
Holidays
k-omega based models; RSM then is pretty good; LES ustimately.
What are you trying to model?
Old   May 5, 2003, 08:03
Michelle
Hello there,
Basically I'm modelling corotating disks in non-axisymmetrical enclosure. I can get a solution.. Actually irregradless of the model used, the velocity always converged to a particular solution. However this solution do not tally with the experimental result.. I can only fine-tune the model to suit the experimental result as I can actually get other results for comparison.. (The experiment was carried out by someone else). My question is what is the best model to capture the flow structure of the problem? I'm not really interested in LES as I'm modelling steady flow..
Old   May 7, 2003, 06:57
heydari
Dear, I have used k-e models, but not k-w, the realizable and rng forms, givw better results in the whole by my experience. you can check out to see the best, and compare it as a good search...
Old   May 7, 2003, 07:00
Holidays
I would try k-w based models (such as SST for example) and then a RSM model (Sarkar Speziale and Gatski for example). The latter should show improved results; what you can do is do a re-start from one of your solution with this upgraded model and compare the evolution of the solution.
Old   May 7, 2003, 07:02
heydari
Old   May 9, 2003, 13:14
Adarsh
try this: segregated solver + RNG K-epsilon +PISO with neighbour and skewness correction Put a monitor of velocity in swirling zone. If RNG k-e does not converge switch to enhanced wall function but be sure that wall yplus is below 4.0
if still problems are there use Realizablek-e K-w models are for low reynolds no applications and SST for external flow simulations specifically. Hope this helps.
Low Reynolds number k-E Turbulent Model Sohail FLUENT 19 July 16, 2020 15:08
flat plate with turbulent model danielcebrian OpenFOAM 10 November 13, 2014 16:47
LamBremhorst turbulent model J0bouchard OpenFOAM 3 February 21, 2013 10:28
Stability problem due to turbulent dispersion force in a subcooled boiling model Edy OpenFOAM 7 August 10, 2011 13:00
Turbulent SST model fergal CFX 13 November 2, 2010 19:15
