"Y+""Y+""Y+""Y+""Y+""Y+"helphelp help!
Old   May 4, 2003, 11:53
Default "Y+""Y+""Y+""Y+""Y+""Y+"helphelp help!
mhf
hello.
what is "Y+"? what does it mean? how do we use it in a simulation in "fluent"? thank you for your answers.
Old   May 4, 2003, 15:19
Default Re: "Y+""Y+""Y+""Y+""Y+""Y+"helphelp help!
Alex Munoz
Hi
Read, Read, Read in boundary conditions
http://www.psc.edu/general/software/.../udf/node2.htm
Regards
Alex Munoz
Old   May 5, 2003, 05:22
Holidays
Read, read, read general fluid mechanics and CFD books
Old   May 5, 2003, 11:24
Default Re: "Y+"
ap
Y+ is the nondimensional distance of a point from the wall (check FLUENT manual for definition).
You should consider Y+ value to generate a grid with a proper density near the wall.
For example, if you use turbulence models with wall-functions, you should have Y+ between 30 and 60, while if you want to use the enhanced wall function, you should have Y+ close to 1.
You can use the Y+ adaption tool from the Adapt menu to check Y+ value and to adapt your grid according to it.
Hi
