Reference value help needed! Urgently!!
Old   April 17, 2003, 19:12
Default Reference value help needed! Urgently!!
Rory Kennedy
Can anyone help me with setting the reference values for a simple 2d aerofoil problem. I am trying to calculate coefficients but am unsure what direction the depth value is in and area values. My chord size is 0.45 metres and the span is 0.8 m.
Does this mean I input 0.8 into the length value and 0.45 into the depth value with the area value as 0.36 m (0.8 x 0.45)?????
Cheers
Old   April 18, 2003, 05:09
Default Re: Reference value help needed! Urgently!!
Jkl
No You Should input 0.8 in the Reference Value/Depth text box, Then you shuold calculate your reference Area Value as Chord*Span and put it in the Reference Value/Area textbox. The input textbox Length is reference value for Moment coefficients calculation,
Hope this could help,
Jkl.
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 05:28
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile val46 OpenFOAM Installation 4 August 27, 2010 04:43
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
