Change Solver
Old   April 16, 2003, 07:38
Default Change Solver
bamboo
I changed the Solver from 2D to Axisymmetric in FLUENT and kept all other items same. But after the Grid Check,there is a WARNING message: Grid check failed. The relative information as following:
Grid Check
Domain Extents:
x-coordinate: min (m) = 0.000000e+00, max (m) = 5.000000e-02
y-coordinate: min (m) = 0.000000e+00, max (m) = 3.500000e-01 Volume statistics:
minimum volume (m3): 6.732661e-12
maximum volume (m3): 8.213853e-06
total volume (m3): 6.383493e-03
minimum 2d volume (m3): 1.953960e-10
maximum 2d volume (m3): 4.264212e-06 Face area statistics:
WARNING: non-positive face area exist.
I am puzzled that it is a 2D problem, why the volume figures shown?
Old   April 16, 2003, 08:35
Default Re: Change Solver
mreip1
When using axisymmetry in Fluent, the axis of rotation has to be on the x-axis. You may correct this inside Fluent with the grid->translate option.
Regards.
Old   April 16, 2003, 08:54
bamboo
3ks a lot, I will try.
Old   April 16, 2003, 09:12
bamboo
3ks a lot , but if i change the model in GAMBIT , then do i need "translate"?
Old   April 16, 2003, 09:34
bamboo
i changed the model in Gambit(rotation 90), to make it on the X-asix,but the Grid Check failed: Grid Check
Domain Extents:
x-coordinate: min (m) = 0.000000e+00, max (m) = 3.500000e+01
y-coordinate: min (m) = -5.000000e+00, max (m) = 2.143061e-15 Volume statistics:
WARNING: non-positive volumes exist.
minimum volume (m3): -5.015160e-01
maximum volume (m3): -1.984904e-04
total volume (m3): -1.044429e+03
minimum 2d volume (m3): 3.960858e-04
maximum 2d volume (m3): 4.154485e-02 Face area statistics:
minimum face area (m2): 1.458132e-03
maximum face area (m2): 1.026326e+00
This time, the volume figures are negetive.
Thanks a lot!
Old   April 16, 2003, 10:21
gforce
Using other mesh types in gambit maybe work.
Phase Change Application - Error in Solver Patrick CFX 2 June 28, 2016 10:49
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
smoothSolver diverges - solution in using PBiCG solver? makaveli_lcf OpenFOAM Running, Solving & CFD 3 September 11, 2013 13:44
Change cell zone index/thread during simulation neilduffy1024 FLUENT 0 January 17, 2011 10:40
Symmetry plane error in solver Santiago Orrego. CFX 6 January 31, 2007 08:09
