Two phase flow Problem
Old   April 14, 2003, 06:04
Default Two phase flow Problem
prasad
hi all, I have vertical chamber with inlet at a height H1 from the bottom. There are two outlet one at the top and other at bottom of the chamber. Also baffeles are present inside the chamber. Fluid is mixture of MUD and GAS which enter the inlet and gets seperated out by means of baffeles.
Is anyone have experience in this kind of problem? Can anyone suggest which model will be appropriate to simulate this kind of problem?
Thanks in advance.
kumar.
Old   May 4, 2003, 11:49
Default Re: Two phase flow Problem
mohammad2
hello. excuse me Mr/Mrs kumar. what's the main problem? I mean is this something available in the world? if yes,what's that? thanks.
error in two phase flow problem mvee FLUENT 0 March 28, 2007 06:17
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 09:10
Two-phase/ Single phase mix flow Reza Main CFD Forum 1 August 6, 2003 07:36
Poiseuille flow problem Rosie FLUENT 1 December 6, 2002 17:52
Two phase flow problem M.Shannag FLUENT 2 December 29, 2001 13:43
