UDF about source term
Old   April 12, 2003, 22:39
Default UDF about source term
tian
hi,all, i want to add a constant value A to u equation source, the udf is low, it's right?
DEFINE_SOURCE(p1_source, c, t, dS, eqn)
{ real A; real source;
source += A; /* A- constant */
return source;
thanks.
tian
Old   April 13, 2003, 00:50
Default Re: UDF about source term
Sebeci
Hi It is right, but you should add dS[eqn]=0 and only it's need to wiite source=A on your code.(if A is constant (dS/du)=0)
I hope this help you
Old   April 17, 2003, 01:34
tian
Hi, Sebeci, thank you. you said that if A is constant,dS/du =0, but in fact, in my u equation, add A to the U equation source, if the dS/du not equal 0, how to do?
tian
Old   May 2, 2003, 10:17
Senthil
that derivative dS is the derivative of the source term w.r.t. the corresponding variable(in single/multi phase flow-both).. So if A is constant, then the derivative should be zero for any transport eqn.
bye
Injection of the source term UDF stage81 FLUENT 0 September 27, 2010 08:20
UDF Source Term Christian FLUENT 4 August 1, 2009 06:53
The source term of UDF summer FLUENT 0 August 24, 2006 18:44
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 14, 2000 00:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 04:43
