help! Mass flow outlet again
Old   April 9, 2003, 11:11
Default help! Mass flow outlet again
Z. T.
In my project, mass-flow-rate in outlet is needed. I have ever tried using the scheme file someone posted before to do that. However, a error in Fluent6 is shown as follows:
Loading "E:\mesh ind\mesh4\mfo.scm"
Error: eval: unbound variable Error Object: )
what does give rise to this error? The scheme file is based on Fluent/UNS. Could anyone help me get one for Fluent5/6?
Thanks!
zheng
Old   April 9, 2003, 11:17
Default Re: help! Mass flow outlet again
HVN
Hello
Why don't you use the surface monitor for that in fluent 6 ?
HV
Old   April 9, 2003, 11:39
HVN
or report with surface integral
Old   April 9, 2003, 11:54
Z. T.
Hi HVN
Thank you for your suggestion. In my case, only pressure in inlet and mass flow rate in outlet is known. so I need special boundary condition.
please see the message as follows:
http://www.cfd-online.com/Forum/flue....cgi?read=1224
Old   April 9, 2003, 12:33
Ahmed
There is no mass flow out boundary condition..In the same time out flow boundary condition cannot be used with compressible flow..therefore I suggest to use pressure outlet BC then you can monitor the mass flow at the outlet then ajust the pressure to get the required mass flow.
Old   April 9, 2003, 13:24
Z.T.
Hello Ahamed:
Thank you for your advice. I think it is good idea. I am thinking, can I prescribe velocity magnitude in outlet by using velocity-inlet(set flow direction as -1)? Is this a way to solve the problem?
Thanks!
zheng
Old   April 10, 2003, 05:42
Hendawi Mohamed
Hello fluently,
I think that in your case, the better solution is to specify a target-mass-flow-rate with pressure-outlet as boundary condition (Cf. /help/html/ug/node198.htm).
for more information you can refer to these messages posted in response to Thierry who is almost in the same case as yours.
http://www.cfd-online.com/Forum/fluent.cgi?read=12288
cordially
Mohamed
P.S.: With Fluent 6 this option is Ok but I don't know if there is some restriction in Fluent 5,
Old   April 10, 2003, 06:18
Thierry
Hello !
Mohamed is right, with FLUENT 6.1.18 you can specify a target-mass-flow-rate with pressure-outlet BC...it's a little bit slow but it seems working.
Thierry.
Old   April 10, 2003, 06:35
Z. T.
Hello Mohamed and Thierry:
Thank you for your help! I am tring to do that.
By the way, I want to ask a question: My project is 2D. In this case, is the depth per unit length(1m) in Fluent by default? I need this value to calculate mass flow rate corresponding to 2D geometry.
Thanks!
Old   April 10, 2003, 09:51
Ahmed
(1)You can specify the profile..
(2)Sure It is 1m, Actually it is convention everywhere..
Old   April 10, 2003, 09:55
  #11
Volker Pawlik
it is always 1 m independet from what you set in reference values panel!!!
Old   April 10, 2003, 09:59
  #12
Volker Pawlik
I must correct my answer to be better understandable:
The massflow you set must be the massflow for a depth of 1 m, independent from what you set as reference depth. Fluent calculates the corresponding massflow for your reference depth!!
Old   April 10, 2003, 13:27
  #13
Z.T.
Thanks to all!
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 13:30
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 03:42
Species mass flow inlet lorenz FLUENT 3 March 15, 2012 08:26
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 14:11
Mass flow rate in outlet Saturn FLUENT 1 October 11, 2004 10:39
