DPM - Particle velocities
Old   April 2, 2003, 15:49
Default DPM - Particle velocities
Umesh Shah
Dear all,
I am simulating particle trajectories for powder coating process.Now,i want to get particle velocities at different positions inside the domain.
Ultimately,i want to have particle velocity profiles with axial positions.
Is there anyway to do so ??
I AM USING FLUENT 6.0.
Thanks,
Umesh
Old   April 2, 2003, 17:28
Default Re: DPM - Particle velocities
Alex Munoz
Yes you can do it
Report>Discrete phase>sample>injection> chose a line or a plane where you want to record you data.
Don't forget to write a UDF output if you only want to write a file with velocity instead of all the variables
Regards
Alex
Old   April 3, 2003, 13:55
Umesh Shah
Thanx Alex,
But you know,in that REPORT>DPM>SAMPLE>>>>
I can record those data on a chosen plane only and also that plane is like cross section of my whole domain so its of not use.Additionally,i get histogram only.
Now i need is the velocity profile of particles with axes .
I tried to chose very thin plane,as an altenative to line.But when i see grid display for that plane,it is not of the size i had given.I dont know how it is.
Can you write me about these things.
Thanx again,
Umesh
DPM particle time step amos FLUENT 1 January 4, 2020 09:46
DPM particle tracking in stirred tank parisa- FLUENT 1 August 7, 2012 13:03
DPM particle tracking parisa- Main CFD Forum 2 June 15, 2011 06:12
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
About Particle velocity of DPM in Fluent? long zhengwei FLUENT 0 March 13, 2009 05:02
