A challegening fluid-solid problem
Old   March 31, 2003, 10:50
Default A challegening fluid-solid problem
majestywzh
just imagine such a following case: a water-solid mulitphase problem,and the solid will melt during its flow,and the solid fraction is not neglectable (20% for instance).it is obvious that none of the provided models in fluent can be used directly to simulate such a case.the mixture model can not predict the secondary solid phase characteristic and the Euler model will not solve energy equation, and the DPM only accounts for the low-fraction situation,and in DPM all the six paticle laws do not inlude the solid melt case? who can give me some suggestions to simplify the problem?
Another Boundary Condition to The Fluid Solid Interface octavyo CFX 10 April 10, 2017 17:57
solid to fluid heattransfer with chtMultiRegionFoam nakor OpenFOAM 11 March 21, 2011 09:28
Fluid - Solid Domain Interface Daniel CFX 6 February 15, 2009 19:09
Extracting fluid flow region from a solid body 3D Pradeep Main CFD Forum 6 January 29, 2009 12:13
Conjugate Heat Transfer between fluid and solid Li Yang Main CFD Forum 8 March 27, 2004 12:05
