grid related solid-fluid flow
Old   March 29, 2003, 23:13
Default grid related solid-fluid flow
majestywzh
1:what are the requirements for the grid when the fluid-solid flow is simulated?if i attach boundary layer near the wall, it is possible the the grid size is smaller than the solid particle size, isn't a bit confused? 2:is that possible for a solid-water flow that the pressre loss is smaller than that in a single water? the solid size 300um,20% volume fraction. use the Mixture model
Old   March 30, 2003, 11:31
Default Re: grid related solid-fluid flow
ap
Grid requirements are the same of a single fluid model. If you use a turbulence model with wall-functions you must have y+ between 30 and 60, while if you use the enhanced wall treatment, you should have y+ close to 1.
I don't think it's physically meaningful to have a grid size smaller than particle diameter.
Why don't you use Eulerian model (just curious)?
Hi. Good work.
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
Theory behind the solid domain rotation in fluid using Bets property Riken CFX 0 October 28, 2009 10:51
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 06:36
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Fluid Structure Interaction Apollo FLUENT 8 July 7, 2004 18:54
