Gambit Error Message
Old   March 20, 2003, 01:05
Default Gambit Error Message
Michelle
I received the following messages when I'm trying to mesh a geometry at level 4 refinement
Unable to Mmap allocate 22020096 bytes from file 12 at 235929600
Assertion failed in MinMeshbase.cc line 571, connectivityArray while meshing volume 1
Have anyone encountered this problem before?
Old   March 20, 2003, 19:25
Default Re: Gambit Error Message
Neezar Alsaiegh
you consumed all your memory,your mesh is bigger than your computer memory.
Neezar
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 07:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 13:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 09:33
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 04:10
Generating big meshes with GAMBIT on NT Andrew Ooi FLUENT 12 February 2, 2000 23:26
