thermal conditions of walls
Old   March 17, 2003, 12:29
Default thermal conditions of walls
Stefan
Hi, i got a problem modelling an adiabatic system. i want to define my walls in a way that there is no energy given from the walls on the system (or let energy escaping from the system) but that the walls temperature is equal to the ones in the fluid cells near the walls. But my problem is that i think i have to put a certain number in the wall temperature textfield in the thermal conditions at the boundary conditions. is there a possibility that the walls have no temperature influence on the flow? Thank you in advance for your help.
Old   March 19, 2003, 04:44
Default Re: thermal conditions of walls
zhhuang
h=0 will be ok
Old   March 23, 2003, 07:17
Stefan
ah, now i understand, i am not allowed to switch to the temperature input panel, just stay at the heat flux and keep it at 0. Thank you for your kind help!
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 18:46
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
