Feeding Data using File in Gambit
Old   March 17, 2003, 08:48
Default Feeding Data using File in Gambit
Sharad
I want to create about 300 Vertices in gambit for creating a complex 3-D geometry. Is it possible to type and save the co-ordinates of the vertices in a proper seuential manner in a file and then read the same vertices in Gambit?
If it is possible please tell me how to do it in DETAIL. Which type of file (text or other) has to be used in that case??
Thanks in advance!
Old   March 17, 2003, 11:34
Default Re: Feeding Data using File in Gambit
jkl
You need to write a journal file. Journal files for Gambit are just ascii text files you can write with a text editor or, if the coordinates of your 300 vertexes are related by some mathematical relationship you can let a subroutine write it for you. You can find more info about using journal files in your USER Documentation in the section named:
PARAMETRIC JOURNALING WITH GAMBIT
read it carefully and pay attention at the syntax of your journal, bacause as far as I know gambit has no debug tools for journal files.
Best Regards,
Jkl.
PS: Take also a look at the journals gambit is writing while you work with its gui. For example to create a vertex in the position (-1,1,0) you will write:
vertex create coordinates -1 1 0
Old   March 17, 2003, 14:09
Sharad
Dear JKL,
Thanks for the reply. My points are haphazard. If I type the vertices in the order I want them in Gambit, in a file using say Notepad (.txt file), then for reading and executing(i.e. creating) those vertices in the desired Gambit file, How do I proceed??
I mean how to read that .txt file in Gambit?
Waiting for your reply.
With regards,
Sharad
Old   March 18, 2003, 05:48
jkl
As you can read in the section PARAMETRIC JOURNALING WITH GAMBIT go to the Gambit menů:
FILE --> Run Journal... --> Edit/Run
Choose using Browse button, the file you've just created. You'd better choose Edit/Run, instead of Run, in the 'Run Journal' window, so that you can select the lines gambit has to execute and you can see what gambit is doing.
Don't forget to read/find on the fulent user area the documentation about PARAMETRIC JOURNAL....
Good Luck,
Jkl.
Old   March 18, 2003, 06:38
An Modh Coinniolach
You could save your xyz points in a file (*.dat) and use the file-import-vertex data menu commands in Gambit to import the points.
I have written a Fortran program to produce the data files for me; I can specify different geometric parameters in the program and the points for that particularly geometry are produced. I use a journal file to import these points, create the geometry from these points, mesh, set boundary conditions and export the mesh file.
Old   March 18, 2003, 14:45
Sharad
Thanx again jkl & An Modh Coinniolach!
I will try what you have suggested.
Regards,
Sharad
Old   March 21, 2003, 14:25
Murali
<font face = "courier new">Another simple way to produce this complex geometry:
(1) Consider columns B,C and D in MS-Excel.
(2) Type all your x y and z co-ordinates in B,C and D columns respectively
(3) Type "vertex create coordinates" (no quotes) in cell A1 and drag it down all the way down column A.
(4) Now you have the following format
A B C D
vertex create coordinates 0 0 1
vertex create coordinates 1 1 1
etc..
(5) Save this as a text file say "mymesh.txt".
(6) Open GAMBIT nad choose "Run journal" from the File menu. The input file would be "mymesh.txt"
(7) All the vertices are plotted. If you are working on unix, you can use K-office or star-office where u have similar spread sheet software. </font>
Old   March 24, 2003, 01:49
Sharad
Dear Murali,
Thanx a lot for such a nice detailed reply. This is most simple way, you have given!
Regards,
Sharad
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 05:59
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
