Where are the CFD masters?
Old   March 14, 2003, 09:54
Default Where are the CFD masters?
zahid
which is Superior approach between TWO? In a pipe flow a 'fan' boundary condition OR a 'momentum source' boudary codition to pump the liquid water.
Old   March 14, 2003, 11:00
Default Re: Where are the CFD masters?
cfd-master
Maybe you should think about not reposting, but instead about rephrasing your question. That would - maybe - make it possible to answer.
Old   March 18, 2003, 21:31
Alex Munoz
Hi
I agree with the last coment your question is not a question!
Use acronames after writting the meaning of them.
So please rewrite your question, tell us about the diameter, Re, fluid, objective of the work, etc.
and made your title related to the problem!
Regards
Alex
Old   March 20, 2003, 05:01
Chetan Kadakia
A fan, I believe will simulate a fan with pressure loss? But I'm not 100% sure.
I don't recall a momentum inlet, but i do recall a mass inlet.
What are your objectives of this solution? If you are just doing a simple pipe flow analysis, then this is not a very important question to ask.
If the solution is more complicate, help us understand why.
Old   March 20, 2003, 07:18
any Q
A staight pipe havind diameter 1 in containing liquid-water, defining a 'velocity_inlet' & an 'outflow' is constucted. Two approches are going to be considered: 1) Anywhere two faces parallel to pipe-inlet are created heving some distance b/w them. splitting the pipe with these faces created three volmes. the middle volume is siad to be a separate vollume and in Fluent it is defined as 'momentum source'. 2) only one face is created parallel to pipe-inlet and that face is defined as 'fan' in Fluent.
Old   March 20, 2003, 18:00
Chetan Kadakia
I apologize, but I am still confused. I really don't understand what you are trying to do.
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 20, 2015 00:40
master's degree and CFD saner Main CFD Forum 1 June 2, 2009 12:50
ASME CFD Symposium, Atlanta, 22-26 July 2001 Chris R. Kleijn Main CFD Forum 0 August 1, 2000 11:07
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 16:01
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 13, 1999 00:27
