Can Brownian force be used in turbulent flow? |
March 12, 2003, 09:22 |
I am trying to simulate the submicron particle transport phenomena in a turbulent flow field. The impact of Brownian effect is critically important. However, in the manual of FLUENT 6.0, it emphasized that Brownain force is intended only for non-turbulent flow (referring to section 19.2.1 and 19.7.4). What is the underlying reason for this limitation? and since the significance of Brownian effect in my model, what can I do to overcome this restriction?
January 2, 2010, 10:20 |
#2 | |
I think by now u know the default BM in fluent does not work. U have to write a udf docnurulhasan@gmail.com |
January 2, 2010, 17:56 |
#3 | |
Rep Power: 18 |
August 3, 2013, 14:21 |
Pouyan talebizadeh
Dear Sir/ madam,
I hope this email finds you well, I read your post in CFD online about the Brownian motion in Fluent. I have some question about this. Would you please help me that 1- Is the Brownian motion modified in Ansys 14 or not? 2- Is there any way I can find the UDF for Brownian motion which I can use in fluent software? Thank you in advance for you time Pouyan |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 07:15 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 06:44 |
modelling laminar and turbulent flow in the same | Ol | FLUENT | 2 | November 25, 2005 03:52 |
Reynolds and Turbulent Flow | Frederic Dubinski | Main CFD Forum | 2 | October 20, 2004 14:57 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
