Heat transfer through solid
Old   March 10, 2003, 07:49
Default Heat transfer through solid
Chris
In the FLUENT manual, it talks about modeling a heated surface between 2 zones, but I do not understand it completely.
I am modeling air flow over a 2-D stream-lined body. There is a constant-temperature heating element (surface) on the bottom surface of the streamlined body. Obviously, there is conduction of heat away from the heating element on the lower surface by the air.
I want to see how much heat is lost through conduction on the upper surface to the flow above the body.
How can I do this, i.e. definition of boundary conditions? My heated element appears with a shadow zone. (?)
Thanks in advance!
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 06:43
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
No Heat Transfer between two solid domains Mike ZH CFX 7 July 26, 2008 17:50
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
