Compressible Flow Modelling?
Old   March 6, 2003, 07:09
Default Compressible Flow Modelling?
yeo
Hi there!
I would like to seek your advice for matter regarding Incompressible and Compressible Flow for my 3D train model and matter about setting the operating pressure.
(1) To quality for incompressible flow field modelling, the Mach number must be low (much less than 1) and density does not vary significantly with time and space. My current Mach number is 0.06, that is train speed 22 m/s, local sound speed 340 m/s.
I had successfully completed this task with incompressible flow field modelling and, Now, if the model is to be modelled with Compressible Flow technique, will the results differ a lot? I had seen in Fluent tutorial about the Sliding Mesh method with similar parameters but model with Compressible Flow technique! Some advise that to create a pressure pulse at the tunnel entry of a train, the density and temperature must change drastically. Actually, my intention is to ensure that my way of modelling is correct.
(2) Is that any difference between setting the operating pressure as 0 Pa or 101325 Pa? Most tutorial suggest the user to to set it at 0 Pa.
regards
Old   March 6, 2003, 10:50
Default Re: Compressible Flow Modelling?
Christian
1) A rule of thumb I use is that if M<0.3, then the flow is incompressible. I have never done a control of this number however. But if it is correct, your case is very much incompressible!
2) If the pressure level is raised, then the density and viscosity will change also. So stick to the pressure that you would expect in the real world. Make sure if the operating pressure is absolute or gauge.
Cheers
Old   March 7, 2003, 00:48
yeo
Thanks Christian for your reply.
What can i get the guidelines for determining the criteria for compressible flow or incompressible flow. That is, the M => 0.3 rule of thumb for gauging compressible. I need the reference to show my supervisor.
thanks a lot.
Old   March 7, 2003, 04:25
Christian
Hi Yeo.
The guideline should be in any fluid dynamics textbook.
Old   March 7, 2003, 08:08
yeo
hi Christian, thanks a lot. I recall now and found it.
best regards
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Incompressible and compressible flow. Confused student. Main CFD Forum 27 March 18, 2017 13:25
modelling blood flow in arteries with starcd sara Siemens 5 April 10, 2007 10:17
Compressible flow - 2D NACA0012 Aerofoil Sim. MSc Student Siemens 3 August 26, 2006 02:32
Modelling Unsteady Compressible Flow Vince Main CFD Forum 0 March 10, 2004 12:01
