Skewness of mesh
Old   March 4, 2003, 10:58
Default Skewness of mesh
Chris
This is about meshing in Gambit.
Does anyone know what is the cause for a mesh to be skewed, and how it may be corrected? I have tried varying the size of the meshes, but it doesn't seem to remove the "offending" skewed grids...
Thanks in advance
Old   March 5, 2003, 04:37
Default Re: Skewness of mesh
Lars
Did you check the Geometry? Sometimes there are "mistakes" in the geometry like two points that are so close together, that they appear as a single edge. This sometimes happens when importing the geometry from other programs. Make shure, that there are no mistakes in the geometry (Zoom in on corners).
Old   March 5, 2003, 05:58
Chris
Hello Lars,
I have tried that. Mine is a 3-D model, so while the faces have non-skewed 2-D meshes, when I do a T-grid volume mesh, it generates 2 or 3 highly skewed 3-D triangular meshes in the middle of the volume!
Do you know what I could do next?
Thanks a mill!
Old   March 5, 2003, 09:35
Lars
I dont know! We had the same problem and I finally set up the problem in Gambit directly, without importing the geometry from autocad. Try meshing only the edges and than mesh the volume directly, without meshing the faces. You can also try to seperate the volume and mesh them with different spacing to get a smaller mesh at the zones that create the problem.
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
High Skewness in Hexcore Mesh/ Tgrid xaero Main CFD Forum 4 November 10, 2009 12:04
Severe nonorthogonality and severe skewness problem qtian OpenFOAM Running, Solving & CFD 2 January 22, 2008 19:47
basic of mesh refinement arya CFX 4 June 19, 2007 13:21
