How can I specify different permeability?
Old   February 25, 2003, 13:54
Default How can I specify different permeability?
Ahmed Khattab
In my case, which is a rectilinear flow in a mold, filled with carbon fiber, I want to change the permeability near the mold wall so the flow front will be faster near the edge (higher permeability near the edgs). So how can I specify different permeability to FLUENT?
Old   March 2, 2003, 22:39
Default Re: How can I specify different permeability?
Murali
<font face = "courier new">I think you should use the Macro DEFINE_PROPERTY
Murali</font>
Old   March 2, 2003, 23:27
Ahmed Khattb
Thanks for your help. I'm new user to FLUENT, so if you please can you help me with more details
Old   March 4, 2003, 18:50
Murali
<font face = "courier new">Since you say that you are new to UDFs, I suggest you peruse the UDF manual which will help you greatly. But let me provide you some tips which I am familiar with:
(1) Since permeability is a 'property' or a number just lilke say diffusivity or viscosity, it can be calculated through a UDF and be passed to FLUENT while running.
(2) The way to do is to use by accessing DEFINE_PROPERTY macro.
(3) If you are completely unfamiliar with UDFs, then these are the preliminary concepts:
cell = computational cell
face = face of the cell
thread = a collection of faces or cells but not both
(4) Since the 'property' of the material is a 'cell value' dependent upon the 'material' of the cell, the DEFINE_PROPERTY Macro would compute your required value and send it to the FLUENT solver while running
(5) Section 4.3.13 of UDF manual of FLUENT 6 gives you this information.
DEFINE_PROPERTY(cell_permeability, c, t)
real perm;
real x[ND_ND];
C_CENTROID(x,c,t);
if (x[0] == 1)
perm = 5;
else
perm = 10;
return perm;
The above example I think should tell you how this works. It first obtains the centroidal information and stores in x, a real array. x[0] has the x co-ordinate and this value is checked. IF x[0] = 1, then the value of permeability to be specified is 5 or else 10.
(6) Once you have written this udf and compiled properly as given in chapter 8 of the UDF manual, you shall see the UDF name appearing in the drop-down list. Select cell_permeability in the appropriate place.
(7) Lastly, all these have been written under the assumption that you have to specify permeability as just a number (and not a relation)
Hope this helps
Murali</font>
Old   March 10, 2003, 17:39
Ahmed Khattab
I'm working to fully understand the UDF manual, but in the example defining the viscosity, and also other examples, there is a drop-down list to select UDF from it, which is not the case for permeability, is that a problem?
Thanks.
How to choose or find Permeability for a Porous screen model using darcy's law.... arunraj CFX 4 September 27, 2011 01:20
Permeability for porous body M_Flodin FLUENT 3 February 22, 2011 09:16
how to assign directional permeability? jemteo CFX 0 April 16, 2006 00:56
correct assignment of permeability? jemteo CFX 0 March 17, 2006 06:34
PEMFC and Permeability Sumon Siemens 1 November 15, 2005 20:22
