Gravity
Old   February 19, 2003, 16:20
Default Gravity
Pravir Kumar Rai
If X-Z axis is in horizontal plane and +Y axis is upwards( gravity is in -Y axis). Now if the flow is in -Y direction what shud be the value of 'g'?? Is it -9.81 or +9.81??? Does the value of gravity depends on the direction of flow or it depends on the orientation of the coorodinate axis??
Old   February 20, 2003, 05:11
Default Re: Gravity
ff
Gravity depends only on the orientation of the coordinate axis.
Old   February 20, 2003, 21:01
Default Re: Gravity
Pravir Kumar Rai
If my model is drawn such that flow is in +Y direction and hence g =-9.81m/s^2. Now I rotate the model and the axis by 180 degrees such that the flow is again in +Y axis but the difference is that +Y axis is now pointing down in the direction of gravity. Would g=+9.81 in this case?????
Old   February 21, 2003, 14:45
Default Re: Gravity
madasu
yes I guess,
it should be +9.81, in case you rotate the model about 180 degrees, since the flow is now towards the -Y direction which adds aditionally the gravitational force to the original acceleration of the flow.
-mp
how to consider gravity in CFX shrimp CFX 4 September 8, 2008 21:41
variation of gravity with time rajani FLUENT 0 February 16, 2005 03:45
Help: gravity in CFX Dejun Jing CFX 2 July 22, 2002 09:58
On gravity modelling... Drona CFX 7 November 22, 2001 11:28
Effects of gravity in pipe - pressure distribution Anthony Wachs FLUENT 2 July 25, 2001 08:07
