Unsteady state case setup
Old   February 12, 2003, 12:00
Default Unsteady state case setup
Christian
I am trying to simulate a tubeflow where the velocity is approx. 20m/s and at the time "t" a pressure rise in the middle of this tube occurs. This pressure rise is only happening once.
How do I make the setup? This case is only a test case to get to know the setup parameters and to learn, so if you need any information for your answer, please just make some up. The important case information is the pressure rise in the middle of the tube.
Any answers are welcome.
Christian
Old   February 15, 2003, 03:15
Default Re: Unsteady state case setup
heydari
Hi, christian, As I understood, your trouble, is to define the pressure value, at the defined location and defined time. I think you should write a sub-routin, for your problem and link it to fluent through, UDF. I think your problem should be calculated az a source term in the momentum equations.
Old   February 16, 2003, 18:11
Erwin
If the pressure increase is instantaneous you could use the Patch function (under Initialize menu) to give a specific fluid zone (or adaption register if you don't have this predefined fluid zone) a new value for the pressure at specific time t. If the pressure increase is more gradual then you'll have to resort to a UDF.
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
A question for unsteady state mech5190 FLUENT 5 May 15, 2009 17:05
using steady state results for unsteady flow siva appanna Main CFD Forum 3 February 20, 2006 06:29
unsteady state problem prasad FLUENT 0 April 4, 2002 23:44
Unsteady state modelling Mehul Kinariwala FLUENT 3 September 1, 2000 10:58
