Running FLUENT in batch mode for Windows OS
Old   February 7, 2003, 17:18
Default Running FLUENT in batch mode for Windows OS
Jake Lee
Can't seem to locate the instructions on how to do just that. Any advice will be appreciated.
Thanks.
Old   February 8, 2003, 05:14
Default Re: Running FLUENT in batch mode for Windows OS
jkl
Old   February 8, 2003, 09:24
Jake Lee
jkl,
i can't read your message, can you repost?
thx
jake
Old   February 8, 2003, 12:03
jkl
I'm sorry I was just reading your one, And I didn't meant to any new message, anyway as far as I know when you want to run Fluent in Batch under Windows OS, you just launch it from the dos prompt as you would on a Unix Machine, except you can't write the outfile, i.e:
fluent version -g -i Journal.jou
And fluent will execute what's written in the journal. When you run fluent in such a way the option -g doesn't eliminate the gui but reduce it to icon, as you can read tipying fluent -help from your command window. I haven't already found a way to make fluent exoprt the output to a specofied file. PS: Don't forget to add Fluent directory to your path.
Best Regards,
Jkl.
Old   February 8, 2003, 13:38
Jake Lee
jkl,
will try that, thx.
jake
Old   June 27, 2009, 01:41
Default hi there
Ali
ali_me84 is on a distinguished road
I want to execute Fluent in batch mode in XP,I want to have Cl and Cd as a result(file),but I have not any output file,I can only run my journal file by this command :
fluent 2d -g -i tast.jou
Please tell me how can I have output file(Cl & Cd).
please help me as soon as possible.
Originally Posted by jkl
;104383
Best Regards,
Jkl.
ali_me84 is offline   Reply With Quote
Old   June 29, 2016, 08:51
Default Running Fluent in batch mode in the windows OS
monika agrawal
monika agrawal is on a distinguished road
Hello Sir/Madam,
I have tried running fluent in batch mode, but getting some error
Process which i followed is :
I kept case file and journal file in folder
open the cmd and changed it to my directory from c to d drive.
than to the folder where i have kept the files
and type the command
fluent 3d -g -i a.jou
but the error which i am getting is 'fluent'' is not recognised as an internal or external command, operable program or batch file
Please help.
Thanks in advance
monika agrawal is offline   Reply With Quote
Old   June 29, 2016, 09:38
Ali
Originally Posted by monika agrawal View Post
Hello Sir/Madam,
Please help.
Thanks in advance
I did that in fluent 2d long time ago. I did run fluent through MATLAB. In your case, first try to run the simulation in fluent, importing the journal file manually in fluent. If this works, you are almost done.
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 05:16
fluent 12.1, batch mode in linux sakalido FLUENT 13 September 27, 2017 09:55
Running fluent with udf in batch mode zonexo Fluent UDF and Scheme Programming 2 March 10, 2012 08:50
Running fluent in Batch model P FLUENT 5 April 8, 2005 12:14
FLUENT 5.2.3 running on PIII 733 Burley Wang FLUENT 7 April 19, 2000 07:03
